Mantra 3 ETA?
Mantra 3 ETA?
I watched a video of Eric Glesser showing new products at the SHOT show. I was intrigued by the Mantra 3.
Key changes for me:
Stainless steel blade (which alloy?)
Compression lock
2nd generation CQI’d bearing system
This might become my first ever titanium bodied folder. None before have been so compelling. Can anyone give a ballpark on when these will ship?
Key changes for me:
Compression lock
Re: Mantra 3 ETA?
I'm pretty sure it's S30V with Peel Ply G10/CF. I would bet these are ready by March but I waited 10 months for the Silverax so I guess we will see. I doubt anyone has a real date unless Sal himself chimes in.
Re: Mantra 3 ETA?
I'm betting it won't since it's G10/CF laminateBill1170 wrote:I watched a video of Eric Glesser showing new products at the SHOT show. I was intrigued by the Mantra 3.
Key changes for me:
Compression lock
Re: Mantra 3 ETA?
Since it wasn't in the last booklet, seems like at best we'll see it the second half of the year
Re: Mantra 3 ETA?
DOH! I forgot that part. You’re correct, of course. I actually prefer G-10 to metal handles. Carbon fiber is good, but my experience with it is super limited.Evil D wrote:I'm betting it won't since it's G10/CF laminateBill1170 wrote:I watched a video of Eric Glesser showing new products at the SHOT show. I was intrigued by the Mantra 3.
Key changes for me:
Compression lock
Re: Mantra 3 ETA?
Thanks. Do we know either the blade alloy or which country it’ll be built in?phaust wrote:Since it wasn't in the last booklet, seems like at best we'll see it the second half of the year
Re: Mantra 3 ETA?
I believe I saw S30V and Taichung.Bill1170 wrote:Thanks. Do we know either the blade alloy or which country it’ll be built in?phaust wrote:Since it wasn't in the last booklet, seems like at best we'll see it the second half of the year
Re: Mantra 3 ETA?
Thanks, David. I guess the current Mantras are from Taichung as well.
Re: Mantra 3 ETA?
Yep. I'm curious about the bearings/pivot. The Sliverax has a 4mm blade and I suspect much of that is for the lock face and to accommodate the milled out recesses that the bearings sit in. I wonder if the Mantra 3 will also be 4mm? The 1/2 were 3mm.Bill1170 wrote:Thanks, David. I guess the current Mantras are from Taichung as well.
Re: Mantra 3 ETA?
Did anyone see specs on the size of the new one? Wondering if its the same as the mantra 2.
Re: Mantra 3 ETA?
The new Spyder Byte just came out. In it, they announced that the Advocate now has the same improvements we see on the Sliverax and Mantra 3. However, BladeHQ lists the Advocate has having a 0.12" blade, which is just over 3mm. So there does not seem to be a standard thickness for blades with the new bearings. Maybe M4 can be thinner due to the toughness of the steel? I hope the M3 has a 3mm blade like the previous versions.Evil D wrote:Yep. I'm curious about the bearings/pivot. The Sliverax has a 4mm blade and I suspect much of that is for the lock face and to accommodate the milled out recesses that the bearings sit in. I wonder if the Mantra 3 will also be 4mm? The 1/2 were 3mm.Bill1170 wrote:Thanks, David. I guess the current Mantras are from Taichung as well.
Re: Mantra 3 ETA?
I'm thinking more about overall thickness. You have to mill out enough recess for the bearings somewhere, either on the tang or liners or maybe both.p_atrick wrote:The new Spyder Byte just came out. In it, they announced that the Advocate now has the same improvements we see on the Sliverax and Mantra 3. However, BladeHQ lists the Advocate has having a 0.12" blade, which is just over 3mm. So there does not seem to be a standard thickness for blades with the new bearings. Maybe M4 can be thinner due to the toughness of the steel? I hope the M3 has a 3mm blade like the previous versions.Evil D wrote:Yep. I'm curious about the bearings/pivot. The Sliverax has a 4mm blade and I suspect much of that is for the lock face and to accommodate the milled out recesses that the bearings sit in. I wonder if the Mantra 3 will also be 4mm? The 1/2 were 3mm.Bill1170 wrote:Thanks, David. I guess the current Mantras are from Taichung as well.
Re: Mantra 3 ETA?
So far I have owned zero ball bearing pivot knives. Bronze washers work great for me. The Mantra 1 is a perfect shape for me, and the Mantra 3 appears to keep that shape while offering changes that boost its attractiveness (to me).
Re: Mantra 3 ETA?
Mantra 3 is up for pre-order on Knife Center if anyone's interested. It's priced at $155.97 which seems about right.
- toocool006
Re: Mantra 3 ETA?
I believe Eric said in one of his SHOT interviews - I can't quite remember which one and I could be misremembering - that the Mantra 3 will be replacing the previous Mantras. Please correct me if I'm wrong on that, but if so does that mean we will see close-out sales on the current generations when they get discontinued? And would you anticipate the discontinuation coming fairly soon on the heels of the Mantra 3 release? Thanks y'all.
~andrew
Re: Mantra 3 ETA?
Any idea when this will hit dealers?
