Gas vs charcoal
- ChrisinHove
Gas vs charcoal
Forget politics, religion and even gun control (or is that politics AND religion?) - what do you prefer and why?
I’ve currently brisket and short ribs on the charcoal smoker, along with some aubergine and whole garlic, staying warm by a wood fired chiminea, and about to cook the accompanying flat breads on the gas grill, so .... err ....I’ve a foot in each camp.
- The Deacon
Re: Gas vs charcoal
It has to be at least 35 years since the last time I cooked with charcoal. Switched to gas in the early 80's, used a George Foreman electric grill when I lived in a ground floor apartment with nowhere to store a gas grill. At present, I go back and forth between a gas grill and a George Foreman grill depending on what, and how much, I am cooking.
- bearfacedkiller
Re: Gas vs charcoal
I guess I prefer charcoal as far as the results go but propane is just so fast and convenient. For that reason propane wins.
Re: Gas vs charcoal
Charcoal. If I want gas I'll cook in the kitchen.
Re: Gas vs charcoal
Haven't grilled in nearly 20 years, but definitely charcoal.
Re: Gas vs charcoal
I prefer charcoal as well.
Re: Gas vs charcoal
I use gas as work my work schedule and children I don't have the time for charcoal.
Adam
Adam
- cabfrank
Re: Gas vs charcoal
For me, gas all day, case closed. Purists will hate.
Re: Gas vs charcoal
Charcoal. I can often be seen making disproportionately large fires in the front yard to cook a small amount of meat.
Re: Gas vs charcoal
Kingsford Charcoal. Preferably, the light the bag kind.
Works like a charm everytime and imo, you just cannot beat the flavor that Kingsford Charcoal gives. That's my 2 shekels worth anyways
Re: Gas vs charcoal
You guys with the time comments, I bet you spend more time exchanging your cylinder than I do lighting briquettes. Matchlight people c'mon. If I'm THAT pressed for time I'm not gonna grill anyway. Grillin = chillin.
Re: Gas vs charcoal
Man, Kingsford Light the bag is awesome.
Burns quick, hot and long. Love me some charcoal
Agree with David. Very fast & grillin and chillin
Re: Gas vs charcoal
Charcoal, but I generally use hardwood lump charcoal over briquettes. Chimney starter with paper, don't even own lighter fluid. I like the hardwood stuff becuase it seems to light faster and burn hotter.
:spyder:
- Naperville
Re: Gas vs charcoal
I don't know when the last time I grilled was, but thanks for giving me the idea. I think sometime in May, I'll get out the charcoal and give it a shot!
I'll make "Hobo Dinners" or cook some salmon fillets. A hobo dinner is when you wrap carrots, potatoes and onions with a hamburger in tin foil and throw it on the grill for 15 to 20 minutes.
- The Mastiff
Re: Gas vs charcoal
Propane and propane accessories including lava rocks. For sure faster and definitely easier to clean up and put away.
Re: Gas vs charcoal
I prefer charcoal hands down. Using gas, I have to put in some of those wood chips in a little can. With charcoal, I can get hickory or mesquite and that is all I need. Nothing beats that smokey flavor.
Re: Gas vs charcoal
Using propane to grill can be exciting.
Re: Gas vs charcoal
Gas for me. Much easier to control temperatures. The only other thing I use outdoors is wood. I haven't used charcoal in at least 15 years.
