{"product_id":"seconds-manix-2-gray-lightweight-maxamet-plainedge","title":"(Seconds) Manix® 2 Lightweight Maxamet®","description":"\u003cp\u003e\u003cstrong\u003ePurchase Limit: 4\u003c\/strong\u003e\u003cbr\u003eThis product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.\u003c\/p\u003e\u003cp\u003eTypically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.\u003c\/p\u003e\u003cp\u003eDue to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.\u003c\/p\u003e\u003cp\u003eAlthough Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.\u003c\/p\u003e\u003cp\u003eThe Manix® 2 Lightweight Maxamet® combines the lightweight construction of our award-winning Manix 2 Lightweight with a blade crafted from Carpenter® steel's Micro-Melt® Maxamet alloy. Maxamet is an extremely hard high-speed powdered tool steel possessing properties that transcend conventional high-speed tool steels and approach those of cemented carbides - the ultra-hard materials used to machine other steels. When Carpenter developed this amazing alloy for the rollers in their steel mills, they sent samples to various companies in the knife industry to evaluate as a blade material. Although many tried, Spyderco was one of only a handful of companies to successfully develop the specialized methods necessary to machine, heat treat, and grind this demanding material to yield reliable, high-performance knife blades.\u003c\/p\u003e\u003cp\u003eThis knife's full-flat-ground, leaf-shaped blade takes full advantage of Maxamet's properties, offering a superior combination of strength, low-friction cutting performance, and point utility. It is supported by Spyderco's patented Ball Bearing Lock™ high-strength lock mechanism that consists of a ball bearing nested within a durable textured polymer 'cage.' When the blade is opened, a steel plunger drives the ball bearing forward to wedge between a ramp on the blade and an 'anvil' in the handle's steel insert. Drawing the caged ball bearing to the rear releases the lock and allows the blade to close smoothly while keeping your fingers safely away from the sharp edge.\u003c\/p\u003e\u003cp\u003eSupporting the lock is an ultra-lightweight handle injection molded from tough fiberglass-reinforced co-polymer (FRCP). It features Spyderco's distinctive Bi-Directional Texturing™ pattern for a secure grip in all environmental conditions and a reversible wire clip that provides convenient left or right-side tip-up carry, making all aspects of the knife's carry and operation completely ambidextrous.\u003c\/p\u003e","brand":"Spyderco","offers":[{"title":"Default Title","offer_id":45591299555372,"sku":"XXC101PGY2","price":79.0,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0562\/7189\/6620\/files\/C101PGY2_Both_013639b4-f394-4ab8-b1f6-58e3220c12d5.jpg?v=1795017734","url":"https:\/\/spyderco.com\/products\/seconds-manix-2-gray-lightweight-maxamet-plainedge","provider":"Spyderco","version":"1.0","type":"link"}
