Sage™ 5 Salt® CPM® MagnaCut® Yellow Black C123GPBKYLMC_Both_V2
Sage™ 5 Salt® CPM® MagnaCut® C123GPBKYLMC_Open_V2
Sage™ 5 Salt® CPM® MagnaCut® C123GPBKYLMC_Closed_V2
Sage™ 5 Salt® CPM® MagnaCut® Black C123GPBKMCBK_Both_V2
Sage™ 5 Salt® CPM® MagnaCut® C123GPBKMCBK_Open_V2
Sage™ 5 Salt® CPM® MagnaCut® C123GPBKMCBK_Closed_V2
Sale price$340.00
Color
Salt® Series expressions of the Sage™ 5 deliver all the proven performance qualities of this popular design in fearlessly corrosion-resistant formats that are ideal for use in and around the water.
Their full-flat-ground, satin-finished blades are crafted from CPM® MagnaCut®—a revolutionary purpose-designed blade steel that defies conventional metallurgical logic to offer an unparalleled balance of edge retention, toughness, and extreme corrosion resistance. These elite blades are housed in easy-to-clean, open-backed handles featuring G-10 scales, nested, skeletonized stainless steel liners, and Spyderco’s signature Compression Lock® mechanism. A reversible deep-pocket wire clip provides a choice of left- or right-side tip-up and is complemented by a generously sized lanyard hole for the easy attachment of fobs, lanyards, and safety lines.
Ideal for tactical applications requiring light discipline, the all-black Sage 5 Salt cloaks its blade in a non-reflective titanium carbonitride (TiCN) blade coating and pairs it with a black-coated pocket clip, liners, and handle hardware. Its handle scales feature both a peel-ply texture and a meticulously machined Caribbean Bi-Directional Texture™ pattern for an ultra-secure grip in all environmental conditions.
For enhanced visibility in and around the water, the Sage 5 Salt is also available with a satin-finished blade and two-tone black-and-yellow handle scales. To guarantee a secure grip, even with wet hands, the scales are painstakingly machined with our signature Caribbean Bi-Directional Texture pattern. This high-traction pattern also reveals the yellow layers of the G-10 for greater visibility in low-light conditions. All the knife’s handle hardware is crafted from ultra-corrosion-resistant marine-grade materials and enhanced by black coatings.
Spyderco will donate approximately 5% of sales of the Sage line to the National Alzheimer's Association Denver, Colorado Chapter. The Alzheimer's Association is the leading voluntary health organization in Alzheimer's care, support, and research. Their mission is to eliminate Alzheimer's disease through the advancement of research, to provide and enhance care and support for all affected, and to reduce the risk of dementia through the promotion of brain health. Contributions to the Alzheimer's Association provide care and support to families in Colorado coping with Alzheimer's disease, as well as fund national programs and research to ultimately find a cure. Visit www.alz.org/co to learn more about how your support makes a difference.
Technical Specifications
Related Products
Recently viewed
