Military™ 2 Carbon Fiber CPM® S90V® Sprint Run® Default Title C36CFP2_Both_copy
Military™ 2 Carbon Fiber CPM® S90V® Sprint Run® C36CFP2_Open_copy
Military™ 2 Carbon Fiber CPM® S90V® Sprint Run® C36CFP2_Close_copy
C36CFP2
Regular price$420.00
This unique, limited-edition expression of the Military™ 2 proudly showcases Crucible® CPM® S90V® blade steel and stunning carbon fiber handle scales. CPM S90V’s advanced alloy composition promotes the formation of hard vanadium carbides instead of chromium carbides, enhancing the steel’s wear resistance while leaving more free chromium available for superior corrosion resistance. The full-flat-ground PlainEdge™ blade of this elite knife takes full advantage of these qualities to deliver unparalleled cutting performance. It is housed in a handle featuring solid carbon fiber scales with a subtle peel-ply texture for a secure grip. Stainless steel liners nested within the scales provide superior structural strength and form the foundation of the knife’s high-strength Compression Lock® mechanism. They also anchor its four-position pocket clip, which supports ambidextrous tip-up or tip-down carry.
Technical Specifications
Related Products
Recently viewed
