Skip to product information
A proud member of Spyderco’s USA-Made family of knives, the Manix® 2 is an extremely capable full-sized folder that is ready for the toughest challenges. Its broad, full flat-ground blade provides exceptional cutting power, while its textured index-finger choil and thumb ramp allow the option of a forward-positioned grip for enhanced control. The blade is supported by our high-strength Ball Bearing Lock™ mechanism, which complements the knife’s fully accessible Trademark Round Hole™ and reversible tip-up pocket clip to make every aspect of the Manix 2’s carry, deployment, and operation completely ambidextrous. The Manix 2 Lightweight features a CTS® BD1N stainless steel blade and a handle injection molded from fiberglass-reinforced co-polymer (FRCP). The lightweight handle features a non-slip Bi-Directional Texture™ pattern, a steel insert around the lock mechanism, and a reversible wire clip for left or right-side tip-up carry. Manix 2 Lightweights with tumbled blade finishes are available with a choice of a black or translucent blue handle. For tactical applications, an all-black configuration is also available, which combines a black FRCP handle, a Diamond-Like Carbon (DLC) blade coating, and matching black-coated handle hardware.
SKU:C101PBBK2
At a glance
3.37in 86mm
CTS® BD1N
United States
Ball Bearing
About
Lock
Ball Bearing
CTS® BD1N
Technical specifications
Overall length:
8in 203mm
Closed length:
4.66in 118mm
Blade thickness:
.125in 3.2mm
Tip carry position:
Tip-Up
Handle material:
FRCP
Knife weight:
2.9oz 82g
Grind:
Clip position:
Ambi
Frequently bought together
