At a glance
1.9in 48mm
VG-10
Japan
Back Lock
About
Spyderco’s Ladybug® epitomizes our family of “Little Big Knives™” that cut with authority far beyond their compact size. Small enough to fit on a keychain, yet capable of tackling serious cutting chores, these diminutive lock-blade folders are a force to be reckoned with. Designed for in-pocket carry, Ladybugs are clipless and feature injection-molded fiberglass-reinforced-nylon (FRN) handles with a high-traction Bi-Directional Texture™ pattern. They are available in several variations offering a choice of blade shapes, steels, grinds, handle colors, and edge configurations. All proudly feature a sturdy back lock mechanism, a generously sized lanyard hole, and our signature Trademark Round Hole™ for convenient, fingernail-free opening.
The standard version of the Ladybug features a hollow-ground blade crafted from VG-10 stainless steel. In a PlainEdge™ format, it is available with a choice of foliage green, purple, or black handle. If you prefer the aggressive cutting power of a SpyderEdge™ blade, the Ladybug is also available with that edge configuration and a black handle.
Technical specifications
Lock
Back Lock
Blade Length:
1.9in 48mm
Overall length:
4.38in 111mm
Closed length:
2.48in 63mm
Edge Length:
1.7in 43mm
VG-10
Blade thickness:
.079in 2mm
Handle material:
FRN
Knife weight:
.7oz 20g
Grind:
Saber
