At a glance
4.3in 109mm
CTS® BD1N
United States
About
Elevated expressions of the classic “offset” kitchen knife, Spyderco’s Z-Cut™ designs position their handles above the level of the blade instead of in line with it to provide greater clearance when working on a cutting board. Blunt-Tip Z-Cuts combine exceptional cutting performance with the enhanced safety of a rounded tip. Their fully serrated CTS® BD1N stainless steel blades are full-flat ground and paired with injection-molded polypropylene handles that come in a choice of red, green, or black.
CTS® BD1N
Technical specifications
Overall length:
8.62in 219mm
Closed length:
in mm
Blade thickness:
.05in 1.3mm
Handle material:
Polypropylene
Knife weight:
1oz 28g
Grind:
