At a glance
6.5in 165mm
MBS-26
Japan
About
Ideal for a wide range of kitchen cutting chores, Spyderco’s handy 6.5-Inch Utility Knife’s MBS-26 stainless steel blade is ground extremely thin and expertly heat treated for exceptional edge retention. Its durable polypropylene handle is injection molded directly onto the blade’s tang and has a distinctive “stepped” texture pattern for a secure grip. The K04 is available in a PlainEdge™ configuration with a black handle and a SpyderEdge™ format with a choice of black or blue handle. SpyderEdge blades feature a unique two-step serration pattern that protects the edge from dulling on cutting boards.
MBS-26
Technical specifications
Overall length:
10.81in 275mm
Closed length:
in mm
Blade thickness:
.053in 1.3mm
Handle material:
Polypropylene
Knife weight:
2oz 57g
Grind:
