At a glance
2.75in 70mm
8Cr13MoV
China
LinerLock
About
Truth be told, one size rarely fits all. For those who want all the qualities and budget-friendly advantages of our iconic Tenacious® model in a slightly smaller package, the Persistence® is the perfect answer. The Persistence Lightweight raises the bar even further, adding the benefit of handle scales injection molded from tough fiberglass-reinforced nylon (FRN). The molded scales reduce its weight by almost 10 percent compared to its G-10-handled counterpart and offer the enhanced grip traction of our signature Bi-Directional Texture™ pattern. All other features are consistent with the original model, including a full-flat-ground 8Cr13MoV stainless steel blade, full, skeletonized stainless steel liners, a four-position pocket clip, and a sturdy LinerLock mechanism. The Persistence Lightweight is available with a satin-finished blade and brightly finished handle hardware with a choice of PlainEdge™, partially serrated CombinationEdge™, or fully serrated SpyderEdge™ configurations. For tactical environments, or for those who simply prefer the look of an all-black knife, it is also available in PlainEdge and SpyderEdge formats with a black oxide blade coating and black-coated hardware.
Technical specifications
Lock
LinerLock
8Cr13MoV
Overall length:
6.85in 174mm
Closed length:
4.12in 105mm
Blade thickness:
.118in 3mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
3.3oz 94g
Grind:
Clip position:
Ambi
