At a glance
4.25in 108mm
8Cr13MoV
China
LinerLock
About
For users with large hands and cutting chores that demand a bigger blade, the Resilience® extends the platform of the budget-friendly Tenacious® to offer a blade with more than four inches of cutting power. The Resilience Lightweight enhances the design even further with handle scales injection molded from durable fiberglass-reinforced nylon (FRN). The molded scales reduce its weight by more than 10 percent compared to its G-10-handled counterpart and offer the non-slip traction of our signature Bi-Directional Texture™ pattern. All other features are consistent with the original model, including a full-flat-ground 8Cr13MoV stainless steel blade, full, skeletonized stainless steel liners, a four-position pocket clip, and a sturdy LinerLock mechanism. The Persistence Lightweight is available with a satin-finished blade and brightly finished handle hardware with a choice of PlainEdge™ or partially serrated CombinationEdge™ formats. For tactical environments, or for those who simply prefer the look of an all-black knife, it is also available in a PlainEdge configuration with a black oxide blade coating and black-coated hardware.
Lock
LinerLock
8Cr13MoV
Technical specifications
Overall length:
9.41in 239mm
Closed length:
5.23in 133mm
Blade thickness:
.118in 3mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
4.5oz 128g
Grind:
Clip position:
Ambi
