At a glance
2.09in 53mm
N690Co
Italy
SlipJoint
About
In early 2013, the Transportation Security Administration (TSA) announced a plan to allow knives in the cabins of airplanes again. Although the plan was later withdrawn, Spyderco was ready for it with an innovative non-locking folder design called the Roadie™. In essence a highly evolved penknife, the Roadie’s full-flat-ground N690Co* sheepsfoot-style blade features a “Double Dent™” for fingernail-free two-handed opening. An improved notched-joint mechanism holds the blade open during use and is backed by a subtle index-finger choil to prevent accidental
closure. Contoured fiberglass-reinforced-nylon (FRN) scales and strategically placed jimping (grooves) on the choil and spine provide comfortable ergonomics that enable this knife to perform well beyond its size. Rapidly setting a new standard in modern pocketknives, the Roadie is available in a choice of black, blue, gray, orange, and red.
* The blade steel for the Roadies is transitioning from N690Co to M398 as the stock of each color is depleted.
Technical specifications
Lock
SlipJoint
N690Co
Overall length:
5.08in 129mm
Closed length:
2.99in 76mm
Blade thickness:
.112in 2.9mm
Handle material:
FRN
Knife weight:
1oz 28g
Grind:
