Para® 3 Salt® Black C223GMCBKP_Both
Para® 3 Salt® C223GMCBKP_Open
Para® 3 Salt® C223GMCBKP_Closed
Para® 3 Salt® Yellow Black C223GBKYLMCP_Both
Para® 3 Salt® C223GBKYLMCP_Open
Para® 3 Salt® C223GBKYLMCP_Closed
Para® 3 Salt®
Sale price$288.00
Color
Following in the footsteps of its groundbreaking bigger brother, the Para Military® 2 Salt®, this remarkable expression of the Para® 3 ushers this practical, pocket-friendly design into Spyderco’s Salt® Series—knives specifically designed for use in and around the water. These elite expressions of the Para 3 boast full-flat-ground blades crafted from CPM® MagnaCut®—a state-of-the-art particle metallurgy steel that offers an exceptional balance of edge retention, toughness, and superior corrosion resistance. Their PlainEdge™ blades are paired with handles featuring G-10 scales and nested stainless steel liners. The skeletonized liners form the foundation of their ultra-reliable Compression Lock® mechanisms, while fully configurable four-position pocket clips provide a choice of left or right-side, tip-up or tip-down carry.
The all-black Para 3 Salt cloaks its blade in a stealthy Diamond-Like Carbon (DLC) coating and its scales are both peel-ply-textured and machined with Spyderco’s signature Caribbean Bi-Directional Texture™ pattern for an ultra-secure grip. Like its DLC-coated blade, this knife’s liners, reversible tip-up pocket clip, and all other hardware are also made from ultra-corrosion-resistant materials and have non-reflective black coatings.
For higher visibility, the Para 3 Salt is also available with a satin-finished blade and two-toned G-10 scales featuring a black and yellow Caribbean Bi-Directional Texture pattern. Its handle hardware is also crafted from ultra-corrosion-resistant, marine-grade materials enhanced by black coatings.
Technical Specifications
Related Products
Recently viewed
