Enuff™ 2 SpyderEdge FB31SBK2_Both
Enuff™ 2 FB31SBK2_Open
Enuff™ 2 FB31SBK2_Sheath
Enuff™ 2 PlainEdge FB31PBK2_Both
Enuff™ 2 FB31PBK2_Open
Enuff™ 2 FB31PBK2_Sheath
Enuff™ 2
Regular price$240.00
Edge Type
Spyderco co-founder Sal Glesser created the original Enuff™ series of fixed-blade knives to emphasize the first few inches of the edge nearest the handle, where most of the work is done. How much blade is “Enuff,” however, is a matter of opinion. For users who love the Enuff platform, but wanted just a bit more blade length, there’s the Enuff 2. It features the same injection-molded, fiberglass-reinforced-nylon (FRN) scales, non-slip Bi-Directional Texture™ pattern, and skeletonized full-tang construction as the original Enuff models, but at 3.93 inches (100mm), its leaf-shaped blade is 43 percent longer. Full-flat ground from 0.118-inch-thick (3mm) VG-10 stainless steel and available in both PlainEdge™ and fully serrated SpyderEdge™ formats, it is also 25 percent thinner. The blade nestles into an injection-molded polymer sheath equipped with a versatile G-Clip™ mount that provides a full range of carry options. For added security, the snap-fit sheath also includes a secondary leather retention strap.
Technical Specifications
Related Products
Recently viewed
