Enuff™ Salt® Default Title FB31SYL_Both
Enuff™ Salt® FB31SYL_Open
Enuff™ Salt® FB31SYL_Sheath
Enuff™ Salt®
FB31SYL
Regular price$216.00
The Enuff™ Salt® integrates the extreme cutting power of a SpyderEdge™ sheepfoot blade with the uncompromising corrosion resistance of H-2 steel. The austenitic properties of its H-2 blade also ensure an exceptionally hard cutting edge and a tough, springy back. Ideal for work in and around the water, it features a skeletonized full-tang construction, high-visibility yellow FRN handle scales, a sure-grip Bi-Directional Texture™ pattern, and a polymer sheath with a versatile G-Clip™ mount. The sheath’s grommeted construction also allows easy attachment to watersports gear.
Technical Specifications
Related Products
Recently viewed
