At a glance
3.58in 91mm
CPM® S30V®
Taiwan
Compression
About
Australian custom knifemaker Alistair Phillips specializes in slim, pocket friendly folders that blend classic styling with modern materials. Based on his custom “Redback” design, the Spyderco Kapara™ faithfully captures his unique style and craftsmanship. Its CPM® S30V® stainless steel blade is full-flat ground for exceptional edge geometry and is paired with a handle featuring full, skeletonized stainless steel liners, a high strength Compression Lock® mechanism, and beautifully contoured solid carbon fiber scales. A contrasting red G-10 backspacer creates a visual accent symbolic of the knife’s original name, while a reversible deep-pocket wire clip offers discreet left or right-side, tip-up carry.
Lock
Compression
CPM® S30V®
Technical specifications
Overall length:
8.27in 210mm
Closed length:
4.69in 119mm
Blade thickness:
.118in 3mm
Tip carry position:
Tip-Up
Handle material:
Carbon Fiber
Knife weight:
3.3oz 94g
Grind:
Clip position:
Ambi
