At a glance
2.92in 74mm
K390
Japan
Compression
About
The Lil’ Temperance® Lightweight is a powerhouse cutting tool and the latest chapter in a long evolutionary history. Although rooted in Martial Blade Craft design, it provides reliable, full-service performance for any cutting task. To elevate that performance even further, this expression of it features a blade crafted from Böhler-Uddeholm, K390 MICROCLEAN®, a state-of-the-art particle metallurgy tool steel formulated to withstand the rigors of the most demanding industrial applications. Full-flat ground from thick 4mm (0.157-inch) stock, the PlainEdge™ blade of this knife is supported by skeletonized stainless steel liners that form the foundation of its high-strength Compression Lock® mechanism. The liners are nested within injection-molded fiberglass-reinforced-nylon (FRN) scales that feature a Bi-Directional Texture™ pattern for a secure, non-slip grip. Molded in the signature blue color of Spyderco’s elite family of K390 knives, the scales are also home to a broad-based four-position clip that supports all possible carry preferences.
Technical specifications
Lock
Compression
K390
Overall length:
7.17in 182mm
Closed length:
4.37in 111mm
Blade thickness:
.16in 4mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
3.8oz 108g
Grind:
Clip position:
Ambi
