Lil' Temperance® 3 Lightweight PlainEdge C69PBK3_Both
PlainEdge
$180.00
Skip to product information
SKU:C69PBK3
SKU:C69PBK3
$180.00
Edge Type
At a glance
2.92in 74mm
VG-10
Japan
Compression
About
The original Lil’ Temperance® was designed by Spyderco co-founder Sal Glesser as a compact yet heavy-duty folding knife suitable for defensive use. Over the years, Sal has refined the design several times, emphasizing its utilitarian function without compromising its hell-for-stout spirit. The latest evolution of this venerable design transcends previous versions by replacing their traditional G-10 handle scales with injection-molded fiberglass-reinforced nylon (FRN). In addition to its light weight, FRN adds the extreme grip security of a deeply molded Bi-Directional Texture™ pattern. Stainless steel liners nested in the scales form the foundation of the knife’s high-strength Compression Lock® mechanism and anchor its broad-based, four-position pocket clip. The stout blade of the Lil’ Temperance 3 is full-flat ground from VG-10 stainless steel has a minimal ricasso to maximize its edge length. It includes a fully accessible Trademark Round Hole™ that proudly announces its Spyderco pedigree and allows swift, positive, one-handed deployment with either hand. Available in a choice of PlainEdge™ or fully serrated SpyderEdge™ formats, the Lil’ Temperance 3 Lightweight is a force to be reckoned with.
Technical specifications
Lock
Compression
VG-10
Overall length:
7.17in 182mm
Closed length:
4.37in 111mm
Blade thickness:
.16in 4mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
3.8oz 108g
Grind:
Clip position:
Ambi
Frequently bought together
Reviews
