At a glance
3.37in 86mm
CPM® Cru-Wear®
United States
Ball Bearing
About
Combining the traditional look of brown canvas Micarta® scales with a CPM® CRU-WEAR® tool steel blade, Spyderco’s “CruCarta” theme has become an instant classic. This stunning expression of the Manix® 2 showcases that distinctive old-school combination with impressive style. Its full-flat-ground, satin-finished blade capitalizes on CPM CRU-WEAR’s advanced alloy composition to deliver exceptional edge retention and toughness. A high-strength Ball Bearing Lock™ mechanism links the blade to a handle constructed with full stainless steel liners and a stainless steel backspacer. The liners are capped with smooth, unpolished Micarta scales that will naturally patina with age and handling to develop their own unique character. To ensure convenient carry and instant access, the handle also features a generously sized lanyard hole and a polished hourglass clip that is reversible for left or right-side tip-up carry.
Lock
Ball Bearing
CPM® Cru-Wear®
Technical specifications
Overall length:
8in 203mm
Closed length:
4.66in 118mm
Blade thickness:
.125in 3.2mm
Tip carry position:
Tip-Up
Handle material:
Micarta
Knife weight:
4.9oz 139g
Grind:
Clip position:
Ambi
