Manix® 2 Lightweight CPM® 15V® Sprint Run® Default Title C101PBN15V2_Both_1
Manix® 2 Lightweight CPM® 15V® Sprint Run® C101PBN15V2_Open_1
Manix® 2 Lightweight CPM® 15V® Sprint Run® C101PBN15V2_Closed_1
Regular price$209.00
This elite Sprint Run® expression of the Manix® 2 Lightweight proudly features a blade crafted from CPM® 15V®, an extraordinary material that offers the highest wear resistance of any cold-work tool steel available today. Containing almost 15 percent vanadium, its unique alloy composition creates an exceptionally high volume of vanadium carbides in its microstructure. In knife blades, this translates to breathtaking cutting performance and edge retention. Spyderco’s limited-edition CPM 15V knives are further enhanced by a specialized heat-treating protocol developed by acclaimed custom knifemaker Shawn Houston. This Sprint Run expression of the Manix 2 Lightweight faithfully includes all the signature elements of this design, including a high-strength Ball Bearing Lock™ mechanism and a reversible tip-up wire pocket clip. To clearly distinguish it as a member of our CPM 15V family, its FRCP (fiberglass-reinforced co-polymer) handle is injection molded in a distinctive brown color and Shawn Houston’s “Triple B” logo is laser engraved on the reverse side of the full-flat-ground blade.
Technical Specifications
Related Products
Recently viewed
