Skip to product information
SKU:MT07
Mule Team™ Damascus MT07P
SKU:MT07
Mule Team™ Damascus
$84.95
At a glance
3.313" (84mm)
D.P.S. 15 Damascus
Japan
About
This model is no longer in production.
Spyderco’s Mule Team™ Series is an ongoing project that enables steel-obsessed knife enthusiasts to test different blade materials using the same exact fixed-blade design platform. Sold without handles or sheaths, Mule Team blades are also ideal for aspiring knifemakers and hobbyists.
This expression of the Mule Team concept features D.P.S. Damascus steel.
Spyderco's Damascus Mule Team is a laminated fifteen-layer steel with a Suminagashi pattern.  The Damascus Mule's steel is composed of layers of erosive and non-erosive material over a VG-10 core center.  The erosive layers are hard martensite stainless steel and the non-erosive layers are anti-corrosion nonferrous metal.   These layers block carbon particles in the core from spreading to the outer layers.  After layering the blade is forged to intentionally distort the layer-lines making a complicated, artistically beautiful pattern called Suminagashi.  Suminagashi is the traditional Japanese art form of creating ripples of Chinese ink on the surface of water.  This steel mimics the art form with interesting results on a knife blade.  Once the layers are distorted, the blade is bathed in acid etching the pattern to vivid relief.
All Mule Team blades are sold consumer-direct and available only at the Spyderco Factory Outlet or through Spyderco.com.
Released October 2010
Technical specifications
Lock
D.P.S. 15 Damascus
Overall length:
7.625 " (194mm)
Closed length:
Blade thickness:
.125 " (3mm)
Tip carry position:
Sheath:
Handle material:
Knife weight:
2.7.oz (76g)
Grind:
Clip position:
Frequently bought together
Reviews
