At a glance
3.50" (89mm)
LC200N
Taiwan
About
This model is no longer in production.
Spyderco’s Mule Team™ Series is an ongoing project that enables steel-obsessed knife enthusiasts to test different blade materials using the same exact fixed-blade design platform. Sold without handles or sheaths, Mule Team blades are also ideal for aspiring knifemakers and hobbyists.
This expression of the Mule Team concept features LC200N steel—a high-nitrogen alloyed tool steel that offers extreme corrosion resistance. This extraordinary material is produced by a combination of the PESR (Pressurized Electric Slag Remelting) process and “smart forging” technology to yield an amazing increase in the steel’s purity and a very fine and homogenous microstructure. LC200N is also a true martensitic steel that achieves its hardness through traditional heat treating, so its hardness level can be precisely controlled to meet the demands of specific uses. Regarded as the material of choice for applications that involve high static and dynamic loads in corrosive environments, LC200N is widely used in the food, chemical, recycling, and pharmaceutical industries, as well as in mirror-polished dies used in the plastics industry. It is best known, however, as NASA’s preferred material for the ball bearings used in their high-performance aerospace equipment.
LC200N’s unique alloy composition includes: 0.3% Carbon, 15% Chromium, 0.5% Nitrogen, 0.95% Molybdenum, 0.5% Nickel, and 1.00% Manganese. When this advanced alloy recipe is translated to knife blades, LC200N provides an exceptional blend of toughness, edge holding, and corrosion resistance.
All Mule Team blades are sold consumer-direct and available only at the Spyderco Factory Outlet or through Spyderco.com.
Released: April 2017
Technical specifications
Lock
LC200N
Overall length:
7.63" (194mm)
Closed length:
Blade thickness:
0.118" (3.0mm)
Tip carry position:
Sheath:
Handle material:
Knife weight:
2.7oz (77g)
Grind:
Clip position:
