Mule Team™ Cobalt Special
MT09
This model is no longer in production.
Spyderco’s Mule Team™ Series is an ongoing project that enables steel-obsessed knife enthusiasts to test different blade materials using the same exact fixed-blade design platform. Sold without handles or sheaths, Mule Team blades are also ideal for aspiring knifemakers and hobbyists.
This expression of the Mule Team concept features Takefu's Cobalt Special blade steel. Takefu is a premier Japanese steel company specializing in the production of steels used for household and industrial cutlery. They produce blades using clad steel. Clad steels are a composite of different metals, some hard, some softer, fused or bonded to each other. Pairing different steel types together elevates performance by combining the best characteristics of each material, and where the steels overlay each other, a fine Hamon or line develops. Traditional Japanese swords featured clad steels, layering tough harder steel with softer bendable ones which resulted in a steel combination that made them difficult to break or bend. Spyderco's MT09 Mule Team is Takefu's Cobalt Special steel enveloped within slices of SUS420J2. The two steels laminated as one boost toughness, improve corrosion resistance, and generate lasting sharpness in a blade that is relatively easy to sharpen.
All Mule Team blades are sold consumer-direct and available only at the Spyderco Factory Outlet or through Spyderco.com.
Released: February 2011
