Mule Team™ M390 MT11
Mule Team™ M390
MT11
Regular price$74.95
This model is no longer in production.
Spyderco’s Mule Team™ Series is an ongoing project that enables steel-obsessed knife enthusiasts to test different blade materials using the same exact fixed-blade design platform. Sold without handles or sheaths, Mule Team blades are also ideal for aspiring knifemakers and hobbyists.
This expression of the Mule Team concept features M390 blade steel.
The Austrian Bohler Group merged with Sweden's Uddeholm Steel Works in 1991, creating the world's largest tool steel manufacturer, Bohler Uddeholm. Specializing in aviation/aerospace and automotive steels, they also produce tool steels used in the manufacture of consumer goods, including electronics and cutlery. Through a powdered metallurgy processes, they produce M390 Microclean steel which is highly sought and well suited to today's high-performance cutlery. M390 is a martensitic chromium steel highly resistant to corrosion. The powdered granules of Chromium and Vanadium in the steel are small, consistently sized, and finely dispersed in the steel's matrix (mix) making it exceptionally homogenous. This means for the consumer cutting with M390 will experience a high-level wear and corrosion resistance and the blade steel can be polished to a mirror-like finish.
All Mule Team blades are sold consumer-direct and available only at the Spyderco Factory Outlet or through Spyderco.com.
Released: June 2011
Technical Specifications
Recently viewed
