Mule Team™ Micro-Melt® PD#1
MT27
Regular price$69.95
This model is no longer in production.
Spyderco’s Mule Team™ Series is an ongoing project that enables steel-obsessed knife enthusiasts to test different blade materials using the same exact fixed-blade design platform. Sold without handles or sheaths, Mule Team blades are also ideal for aspiring knifemakers and hobbyists.
This expression of the Mule Team concept features Carpenter® steel's Micro-Melt® PD#1 alloy—an air-hardening cold-work die steel. PD#1's unique alloy composition gives it wear resistance significantly superior to conventional steels like D2, while still maintaining excellent toughness. Thanks to Carpenter's advanced Micro-Melt powder metallurgy process, PD#1 possesses an extremely fine microstructure and uniform carbide distribution, as well as the enhanced compressive strength necessary for the demands of tooling applications. Collectively, these qualities give it a unique combination of wear resistance and toughness that make it ideal for use as a blade steel.
PD#1's unique alloy composition includes: 1.1% Carbon, 7.75% Chromium, 1.2% Silicon, 1.6% Molybdenum, 1.1% Tungsten, 0.25% Manganese, and 2.35% Vanadium. Note that its moderate Chromium content provides only limited corrosion resistance, so please maintain your knife properly.
All Mule Team blades are sold consumer-direct and available only at the Spyderco Factory Outlet or through Spyderco.com.
Released: October 2017
Technical Specifications
Recently viewed
