Mule Team™ 2 Straight Spine Boltaron® Sheath Default Title MTSH2_Both
MTSH2
Regular price$40.00
This custom-molded Boltaron® sheath provides the perfect turnkey carry solution for Spyderco’s Mule Team™ 2 CPM® SPY27® blade. It is specifically designed to fit that straight-spined, full-production blade when it is equipped with our “bolt-on” G-10 handle scales (sold separately) and does not accept other Mule Team blades. This sheath’s snap-fit retention holds the knife securely while leaving most of the handle exposed for a quick, positive draw. It comes complete with a fully configurable G-Clip™ attachment that supports both belt carry and clip-on inside-the-waistband carry. Angle adjustable for vertical, horizontal, or canted positioning, the G-Clip can also be mounted on either side of the symmetrical sheath for edge-forward or edge-back carry. This high-quality sheath is also assembled with eyelets instead of rivets to allow it to be easily lashed or zip-tied to packs and other platforms.
Technical Specifications
Related Products
Recently viewed
