At a glance
4.08in 104mm
CPM® Cru-Wear®
United States
Back Lock
About
More of a good thing is always better, especially when it comes to Spyderco’s incredibly popular “CruCarta” themed knives. In this case, “more” takes the form of the Native Chief®—an extended version of the popular Native® 5. Faithfully offering all the same qualities as its progenitor, but in a longer, even more capable format, this expression of the Native Chief showcases a full-flat-ground, satin-finished blade precision machined from CPM® CRU-WEAR® tool steel. The blade is housed in a handle constructed with smooth brown canvas Micarta® scales, a high-strength back lock mechanism, a stainless steel backspacer, and a fully configurable four-position pocket clip. A truly impressive example of this “old-school” pairing of materials, this Native Chief commands attention.
Technical specifications
Lock
Back Lock
CPM® Cru-Wear®
Overall length:
9.08in 231mm
Closed length:
5.08in 129mm
Blade thickness:
.13in 3.2mm
Tip carry position:
4-Position
Handle material:
Micarta
Knife weight:
3.7oz 104g
Grind:
Clip position:
Ambi
