Pacific Salt® 2 Green LC200N PlainEdge C91FPGR2_Both
PlainEdge
$202.00
Skip to product information
SKU:C91FPGR2
SKU:C91FPGR2
$202.00
Edge Type
At a glance
3.78in 96mm
LC200N
Japan
Back Lock
About
The Pacific Salt® 2 proudly offers all the key features of the iconic Endura® 4 Lightweight in an ultra-corrosion-resistant format. These include refined ergonomics, a high-traction Bi-Directional Texture™ pattern on the handle, a high-strength back lock mechanism, and a black-coated titanium pocket clip that supports left or right-side, tip-up or tip-down carry. Unlike the Endura 4, which uses stainless steel liners in the handle, the Pacific Salt 2’s incredibly lightweight linerless handle is molded from two pieces of fiberglass-reinforced nylon (FRN) and fitted with four sets of threaded stainless steel inserts to mount its four-position clip. All other metal hardware on the Pacific Salt 2 is also machined from special marine-grade alloys and black coated for extreme corrosion resistance.
This expression of the design showcases a full-flat-ground blade crafted from LC200N martensitic blade steel. This nitrogen-enriched alloy offers both exceptional resistance to corrosion and excellent edge-holding properties. Available in both PlainEdge™ and fully serrated SpyderEdge™ formats, this remarkable knife features a high-visibility green handle color that is a signature of Spyderco’s LC200N family.
Lock
Back Lock
LC200N
Overall length:
8.72in 221mm
Closed length:
4.98in 126mm
Blade thickness:
.116in 2.9mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
2.6oz 72g
Grind:
Clip position:
Ambi
Frequently bought together
Reviews
