Para® 3 CPM® S110V® Default Title C223GPDBL_Both
Para® 3 CPM® S110V®
$329.00
Skip to product information
SKU:C223GPDBL
SKU:C223GPDBL
Para® 3 CPM® S110V®
$329.00
At a glance
2.93in 74mm
CPM® S110V®
United States
Compression
About
This elite version of the Para® 3 supercharges the performance of this compact design with state-of-the-art CPM® S110V® blade steel. In its basic form, the Para 3 distills all the best-in-class features and benefits of the iconic Para Military® 2 into a smaller, more pocket-friendly format. When enhanced with CPM S110V, its full-flat-ground PlainEdge™ blade achieves even higher levels of wear resistance and corrosion resistance—qualities that optimize its performance as a cutting tool. CPM S110V’s high carbon content, advanced alloy mix, and high volume of vanadium and niobium carbides significantly increase the steel’s edge-holding properties as compared to other particle metallurgy steels. This extreme edge retention complements the Para 3’s many other distinguishing features—exceptional ergonomics, a high-strength Compression Lock® mechanism, and versatile four-position pocket clip—to make it one of the most capable production folding knives available today. To make it even more special, this remarkable expression of the Para 3 proudly wears textured G-10 handle scales in the deep midnight blue color that is a signature of Spyderco’s CPM S110V breed.
Lock
Compression
CPM® S110V®
Overall length:
7.2in 183mm
Closed length:
4.29in 109mm
Blade thickness:
.145in 3.7mm
Tip carry position:
4-Position
Handle material:
G-10
Knife weight:
3.4oz 96g
Grind:
Clip position:
Ambi
Frequently bought together
Reviews
