At a glance
3.45in 88mm
CPM® S45VN®
United States
Compression
About
Left-handers rejoice! The Spyderco Para Military® 2, hands down one of our most popular and in-demand models, is now available in a purpose-designed left-handed version.
Like the best-selling right-handed Para Military 2, this version features a full-flat-ground CPM® S45VN® stainless steel blade with an oversized Trademark Round Hole™ that is fully accessible for swift, ambidextrous, one-handed opening. The blade is housed in a handle constructed with stainless steel liners nested within durable textured G-10 scales. This pocket-friendly style of construction results in a slimmer profile and allows an open-backed design that reduces weight and simplifies cleaning and maintenance. It is also the foundation of the knife’s Compression Lock® mechanism, which in this knife is specifically engineered for left-handed operation. This “mirror-image” version of the Compression Lock provides the same trustworthy strength and ease of operation but is specifically configured for left-handed use.
The left-handed Para Military 2 also features a four-position pocket clip that supports tip-up or tip-down carry on both sides of the body. A generously sized lined lanyard hole at the butt end of the handle completes the package, allowing the easy attachment of fobs, lanyards, and safety lines.
Technical specifications
Lock
Compression
CPM® S45VN®
Overall length:
8.26in 210mm
Closed length:
4.82in 122mm
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Handle material:
G-10
Knife weight:
3.8oz 108g
Grind:
Clip position:
Ambi
