At a glance
3.47in 88mm
CPM® Cru-Wear®
United States
Compression
About
This stunning expression of the iconic Para Military® 2 pairs a CPM® CRU-WEAR® blade with classic brown canvas Micarta® handle scales; Spyderco's “CruCarta” theme has become a popular classic. Its full-flat-ground PlainEdge™ blade capitalizes on CRU-WEAR’s hard-earned reputation for taking and holding a superior edge while remaining tough and resilient.
The precision-machined scales are supported by full skeletonized stainless steel liners that also form the backbone of the knife’s Compression Lock® mechanism. They reveal the Micarta’s handsome layered construction and provide a platform for a four-position pocket clip and lined lanyard hole that support all possible carry positions and preferences.
Technical specifications
Lock
Compression
Blade Length:
3.47in 88mm
Overall length:
8.29in 211mm
Closed length:
4.82in 122mm
Edge Length:
3.1in 79mm
CPM® Cru-Wear®
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
Micarta
Knife weight:
3.9oz 111g
Grind:
