Para Military® 2 Red/Black G-10 CPM® MagnaCut® Crucible
C81GBKRDMCBKP2
SOLD OUT - No Longer Available
A tribute to an era of innovation. This USA-made Para Military 2 was created to honor Crucible Industries and was originally available only to Crucible employees. Now, for the first and only time in this configuration, it will be available in extremely limited quantities. Purchase limits apply.
The first defining feature of this elite knife is its blade, which is crafted from Crucible's own CPM® MagnaCut® powder metallurgy stainless steel. Conceived by Larrin Thomas, a Doctor of Philosophy (Ph.D.) in Metallurgical and Materials Engineering, MagnaCut challenges traditional stainless steel chemistry by reducing the amount of chromium in the steel to a precise range while adding vanadium and niobium. The result is a state-of-the-art blade steel that offers an exceptional balance of edge retention, toughness, and extreme corrosion resistance. Full-flat ground for optimal edge geometry, the blade of this knife takes full advantage of these properties to deliver unparalleled cutting performance. It also features a handsome black Diamond-Like Carbon (DLC) coating that proudly showcases a laser-engraved Crucible Industries logo.
Not to be outdone, the handle scales of this Exclusive knife are crafted from peel-ply-textured G-10 featuring alternating red and black layers. Spyderco’s signature Caribbean Bi-Directional Texture™ pattern is painstakingly machined into the scales' red surface layer, revealing the underlying black layer and creating a high-visibility, color-contrasting, non-slip pattern. To complement its DLC-coated blade, the knife’s nested stainless steel liners, fully configurable four-position pocket clip, and other hardware also feature matching black coatings. All other features of this knife are faithfully consistent with the time-tested Para Military 2 platform, including its signature Compression Lock® mechanism and its lightweight, easily cleaned, open-backed construction style.
A truly remarkable rendition of one of Spyderco's most iconic designs, this Exclusive version of the Para Military 2 is sure to become a coveted collector's item.
Additional discounts do not apply.
