Persistence® Lightweight CPM® S35VN™ PlainEdge™
At a glance
2.75in 70mm
CPM® S35VN®
China
LinerLock
About
The Persistence® Lightweight combined the compact size and proven features of this time-tested design with the weight-saving advantages of injection-molded fiberglass-reinforced-nylon (FRN) scales. This version takes that evolution a step further, supercharging its performance with American-made CPM® S35VN™ blade steel. The unique chemistry of this steel promotes the formation of niobium carbides along with vanadium and chromium carbides, enhancing its toughness without sacrificing wear resistance. The full-flat-ground blade of this knife is available in all three edge configurations and is paired with a handle featuring bright blue FRN scales, non-slip Bi-Directional Texturing™, a sturdy LinerLock mechanism, and a versatile four-position pocket clip.
Technical specifications
Lock
LinerLock
CPM® S35VN®
Overall length:
6.85in 174mm
Closed length:
4.12in 105mm
Blade thickness:
.12in 3mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
3.3oz 94g
Grind:
Clip position:
Ambi
