Sage™ 6 Button-Release Compression Lock® Carbon Fiber CPM® S90V® Sprint Run® Default Title C123CFBCLS90VP_Both
$400.00
Skip to product information
SKU:C123CFBCLS90VP
SKU:C123CFBCLS90VP
$400.00
At a glance
3in 76mm
CPM® S90V®
Taiwan
Compression
About
The sixth installment in Spyderco’s unique Sage™ Series, the Sage 6 showcases the Button-Release Compression Lock® pioneered by custom knifemaker Kevin Smock. A novel variation of the Sal Glesser-designed Compression Lock mechanism, it not only makes closing the knife simpler and easier but also establishes the Sage 6 one of our most “fidget-friendly” models. This elite Sprint Run expression of the design supercharges it with a full-flat-ground blade crafted from CPM® S90V® particle metallurgy stainless steel and solid carbon fiber scales. The enhanced, vanadium-rich blade steel offers a superior blend of edge retention and corrosion resistance, while the peel-ply-textured scales balance stunning aesthetics and a non-slip texture. Like all Sage models, this limited-edition knife features a reversible deep-pocket wire clip for discreet tip-up carry on either side of the body.
Spyderco will donate approximately 5% of sales of the Sage line to the National Alzheimer's Association Denver, Colorado Chapter. The Alzheimer's Association is the leading voluntary health organization in Alzheimer's care, support, and research. Their mission is to eliminate Alzheimer's disease through the advancement of research, to provide and enhance care and support for all affected, and to reduce the risk of dementia through the promotion of brain health. Contributions to the Alzheimer's Association provide care and support to families in Colorado coping with Alzheimer's disease, as well as fund national programs and research to ultimately find a cure. Visit www.alz.org/co to learn more about how your support makes a difference.
Lock
Compression
CPM® S90V®
Overall length:
7.13in 181mm
Closed length:
4.17in 106mm
Blade thickness:
.118in 3mm
Tip carry position:
Tip-Up
Handle material:
Carbon Fiber
Knife weight:
3.1oz 88g
Grind:
Clip position:
Ambi
Frequently bought together
Reviews
