At a glance
3in 76mm
LC200N
Japan
Back Lock
About
The Salt® 2 offers all the salient features of the best-in-class Delica® 4 Lightweight model in a format that offers extreme corrosion resistance. These include enhanced ergonomics, a high-traction Bi-Directional Texture™ pattern on the handle, a high-strength back lock mechanism, and a black-coated titanium pocket clip that supports left or right-side, tip-up or tip-down carry. Unlike the Delica 4, which uses stainless steel liners in the handle, the Salt 2’s ultra-lightweight linerless handle is molded from two pieces of fiberglass-reinforced nylon (FRN) and fitted with four sets of threaded stainless steel inserts to mount its four-position clip. All other metal hardware on the Salt 2 is also machined from special marine-grade alloys and black coated for extreme corrosion resistance.
This expression of the Salt 2 showcases a full-flat-ground blade crafted from LC200N martensitic blade steel. This nitrogen-enriched alloy offers both exceptional resistance to corrosion and excellent edge-holding properties. Available in both PlainEdge™ and fully serrated SpyderEdge™ formats, this remarkable design features a high-visibility green handle color that is a signature of Spyderco’s LC200N family.
Technical specifications
Lock
Back Lock
LC200N
Overall length:
7.2in 183mm
Closed length:
4.25in 108mm
Blade thickness:
.098in 2.5mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
1.9oz 54g
Grind:
Clip position:
Ambi
