At a glance
3.61" (92mm)
CTS 204P
United States
Compression
About
This limited-edition Exclusive version of the Spyderco Shaman™ was specially manufactured for KnifeWorks (Knifeworks.com) and is available only through their sales channels.
The first defining feature of this elite knife is its blade, which is precision machined from Carpenter® Technology CTS® 204P, an advanced powder-metallurgy stainless steel that offers an exceptional balance of wear resistance, toughness, and corrosion resistance. The full-flat-ground, satin-finished PlainEdge™ blade of this knife takes full advantage of these qualities, while offering optimal edge geometry and point utility that make it an outstanding everyday-carry cutting tool.
Equally unique, the handle of this elite knife proudly showcases smooth forest green G-10 scales. The scales are painstakingly machined to create comfortable, radiused edges and to house nested stainless steel liners that form the foundation of the knife's high-strength Compression Lock® mechanism. To ensure ease of carry and instant access, the handle also includes a polished four-position pocket clip configurable for left or right-side, tip-up or tip-down carry.
Technical specifications
Lock
Compression
CTS 204P
Overall length:
8.26" (210mm)
Closed length:
4.70" (119mm)
Blade thickness:
0.145" (3.7mm)
Tip carry position:
4-position
Handle material:
G-10
Knife weight:
5.2oz (147g)
Grind:
Clip position:
Ambi
