Skoli™ None FB53GPBoth
Skoli™
None
$190.00
Skip to product information
SKU:FB53GP
Skoli™
$190.00
Blade Coating
At a glance
4.68in 119mm
9Cr18MoV
China
None
About
Designed by custom knifemaker Kevin Smock, the Skoli is an all-purpose fixed-blade knife ideal for outdoor adventure. Its versatile design draws from Smock’s own extensive hunting and camping experience and emphasizes comfort, grip security, and a well-centered, utilitarian point. The Skoli’s blade is crafted from 9Cr18MoV stainless steel and features a modified sheepfoot profile and a flat grind for a superior balance of strength and low-friction edge geometry. Its full tang is flanked by precision-machined, contoured G-10 scales with a high-traction checkered texture pattern. A single quillon (guard) at the front of the handle and a section of jimping (textured grooves) on the spine complement the textured scales to ensure a secure grip and exceptional control in even the most demanding conditions. The Skoli is available with a choice of two finish options: a handsome stonewashed finish or a black oxide coating that eliminates its reflective signature. To complement its low-profile coating, the black-bladed Skoli also features black-coated handle hardware. Both versions come complete with a custom-molded, snap-fit Boltaron® sheath and a versatile G-Clip® mount that supports angle-adjustable carry on the belt and inside the waistband.
Technical specifications
Lock
None
Blade Length:
4.68in 119mm
Overall length:
9.32in 237mm
Closed length:
in mm
Edge Length:
3.95in 100mm
9Cr18MoV
Blade thickness:
.15in 3.8mm
Sheath:
Boltaron
Handle material:
G-10
Knife weight:
5.2oz 146g
Grind:
Flat
Frequently bought together
Reviews
