SpydieChef™ Default Title C211TIP_Both
SpydieChef™ C211TIP_Open
SpydieChef™ C211TIP_Closed
SpydieChef™
C211TIP
Regular price$424.00
Based on renowned Polish knifemaker Marcin Slysz’ custom design, the SpydieChef™ translates the user-friendly ergonomics of a good chef’s knife into a do-all, everyday-carry folder. Its gracefully curved, full-flat-ground blade is crafted from LC200N—an extremely corrosion-resistant nitrogen-enriched steel used by NASA for ball bearings. The satin-finished blade is paired with an easily cleaned, open-backed handle featuring two solid titanium scales, one of which houses a stout Reeve Integral Lock™ (R.I.L.) mechanism. A lined lanyard hole and a reversible deep-pocket wire clip provide convenient tip-up carry, while an enhanced coating on all the handle hardware maximizes the knife’s resistance to corrosion.
Technical Specifications
Related Products
Recently viewed
