At a glance
3.43in 87mm
VG-10
Japan
Back Lock
About
Optimized for field dressing game but perfect for all everyday cutting chores, the Stretch™ 2 Lightweight’s refined ergonomics minimize fatigue during prolonged use. They are complemented by an index-finger choil that allows a forward-positioned grip for enhanced control during precise work. The knife’s full-flat-ground VG-10 stainless steel blade features a classic drop-point profile and is paired with a molded fiberglass-reinforced-nylon (FRN) handle. The handle has a deep Bi-Directional-Texture™ pattern for a secure grip in all conditions and is reinforced by skeletonized stainless steel liners. It is also home to the knife’s stout back lock mechanism and a four-position pocket clip that supports all possible carry positions.
Technical specifications
Lock
Back Lock
VG-10
Overall length:
8.14in 207mm
Closed length:
4.71in 120mm
Blade thickness:
.12in 3mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
3.7oz 105g
Grind:
Clip position:
Ambi
