At a glance
4.46in 113mm
CPM® Cru-Wear®
Japan
About
Designed by Spyderco co-founder Sal Glesser, the Temperance™ was one of our earliest fixed-blade models. Now this classic design is back as a limited-edition Sprint Run®, showcasing a gray-colored fiberglass-reinforced-nylon (FRN) handle and a full-flat-ground blade crafted from CPM® CRU-WEAR® tool steel. Specially formulated to offer both superior wear resistance and toughness, CRU-WEAR’s advanced alloy composition is further enhanced by the Crucible Particle Metallurgy (CPM) process to ensure an ultra-fine, extremely homogeneous grain structure. Faithful to the original, the knife’s ergonomic handle is injection molded directly onto the tang of the blade and features a series of bilateral “dimples” to enhance its texture and provide pivot points for grip-change maneuvers. This remarkable resurrection of the Temperance is available in both PlainEdge™ and fully serrated SpyderEdge™ configurations. Both include a custom-molded Boltaron® sheath with a versatile G-Clip™ attachment that supports both belt and inside-the-waistband carry.
Technical specifications
CPM® Cru-Wear®
Overall length:
9.42in 239mm
Closed length:
in mm
Blade thickness:
.157in 4mm
Sheath:
Boltaron
Handle material:
FRN
Knife weight:
5.4oz 153g
Grind:
