At a glance
3.2in 81mm
CPM® 15V®
United States
Compression
About
This elite Sprint Run® expression of the Yojimbo™ 2 proudly showcases a blade crafted from CPM® 15V®, an extraordinary material that offers the highest wear resistance of any cold-work tool steel available today. Containing almost 15 percent vanadium, its unique alloy composition creates an exceptionally high volume of vanadium carbides in its microstructure. In knife blades, this translates to breathtaking cutting performance and edge retention. Spyderco’s limited-edition family of CPM 15V knives are further enhanced by a specialized heat-treating protocol developed by acclaimed custom knifemaker Shawn Houston. This Sprint Run expression of the Yojimbo 2 faithfully includes all the proven elements of this design, including a high-strength Compression Lock® mechanism and a four-position pocket clip. To clearly distinguish it as a member of our CPM 15V family, it also features brown peel-ply-textured G-10 handle scales and Shawn Houston’s “Triple B” logo laser engraved on the reverse side of the hollow-ground blade.
Lock
Compression
CPM® 15V®
Technical specifications
Overall length:
7.69in 195mm
Closed length:
4.49in 114mm
Blade thickness:
.145in 3.7mm
Tip carry position:
4-Position
Handle material:
G-10
Knife weight:
4.1oz 116g
Grind:
Hollow
Clip position:
Ambi
