YoJumbo™ DLC C253GPBBK_Both
YoJumbo™
DLC
$318.00
Skip to product information
SKU:C253GPBBK
SKU:C253GPBBK
YoJumbo™
$318.00
Blade Coating
At a glance
3.98in 101mm
CPM® S30V®
United States
Compression
About
Michael Janich’s Yojimbo™ 2 design was instrumental in defining the genre of the “tactical Wharncliffe.” His YoJumbo™ builds on that success, scaling the design up by over 20 percent and refining its ergonomics to accommodate a wider range of hand sizes.
The YoJumbo’s formidable four-inch (102mm) Wharncliffe blade is hollow ground from CPM® S30V® stainless steel for superior edge geometry and features a fully accessible Trademark Round Hole™ for swift, ambidextrous, one-handed opening. Its handle showcases easy-to-clean, open-backed construction and nested, skeletonized stainless steel liners. These features keep the knife’s weight to a minimum, while its coarse-textured G-10 scales promote a secure, non-slip grip. The liners also form the foundation of its high-strength Compression Lock® mechanism and anchor its four-position pocket clip, which is configurable for tip-up or tip-down carry on either side of the body. A truly formidable cutting tool optimized for personal-defense use, the YoJumbo is available with a satin-finished blade and brightly finished hardware and in an all-black configuration with a Diamond-Like Carbon (DLC) blade coating and black-coated liners, clip, and handle hardware.
Technical specifications
Lock
Compression
CPM® S30V®
Overall length:
9.29in 236mm
Closed length:
5.37in 136mm
Blade thickness:
.145in 3.7mm
Tip carry position:
4-Position
Handle material:
G-10
Knife weight:
5.3oz 150g
Grind:
Hollow
Clip position:
Ambi
Frequently bought together
Reviews
