Skip to product information
The Harrier™ 2 Lightweight delivers all the utilitarian qualities of this utilitarian design in a weight-saving format that is over 20 percent lighter than its G-10-handled counterpart. Its injection-molded fiberglass-reinforced-nylon (FRN) scales are reinforced by nested stainless steel liners and feature a non-slip texture to ensure a secure grip. The 8Cr13MoV stainless steel blade is full-flat ground for optimal edge geometry, has a textured index-finger choil and thumb ramp, and is available in a choice of a PlainEdge™ or partially serrated CombinationEdge™ configuration. A four-position clip completes the package, offering ambidextrous tip-up or tip-down carry.
SKU:BY01PBK2
At a glance
3.36in 85mm
8Cr13MoV
China
Back Lock
About
Technical specifications
Lock
Back Lock
Blade Length:
3.36in 85mm
Overall length:
7.62in 194mm
Closed length:
4.32in 110mm
Edge Length:
2.89in 73mm
8Cr13MoV
Blade thickness:
.11in 2.8mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
FRN
Knife weight:
2.7oz 77g
Grind:
Frequently bought together
