Skip to product information
In 1990, Spyderco’s original Delica® helped revolutionize pocketknife design as one of the first lightweight, clip-carry folders. More than 30 years and four generations later, it is one of the most widely recognized knives in the world and still sets the standard for its breed. Current Delica 4 Lightweight models feature handles injection molded from tough fiberglass-reinforced nylon (FRN) and structurally reinforced with nested, skeletonized stainless steel liners. They include a high-traction Bi-Directional Texture™ pattern for a secure grip and are also home to a sturdy back lock mechanism and a four-position pocket clip that allows a choice of left or right-side, tip-up or tip-down carry. Delica 4 Lightweights with saber-ground blades offer an excellent balance of strength and cutting performance and are available in several different configurations, all crafted from VG-10 stainless steel. The black-handled versions with satin-finished blades are available in a choice of PlainEdge™, partially serrated CombinationEdge™, or fully serrated SpyderEdge™ formats. The CombinationEdge configuration is also available with a satin finish and a foliage green-colored handle and in an all-black version with a black handle, titanium carbonitride (TiCN) blade coating, and matching black-coated handle hardware.
SKU:C11PSBBK
At a glance
2.9in 74mm
VG-10
Japan
Back Lock
About
Technical specifications
Lock
Back Lock
Blade Length:
2.9in 74mm
Overall length:
7.11in 181mm
Closed length:
4.25in 108mm
Edge Length:
2.56in 65mm
VG-10
Blade thickness:
.098in 2.5mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
FRN
Knife weight:
2.6oz 74g
Grind:
Saber
Frequently bought together
