At a glance
3.14in 80mm
VG-10
Japan
Back Lock
About
Widely known in the knife industry as the “Godfather of Knifemaking,” the late Frank Centofante was highly respected for his elegant designs and painstaking craftsmanship. The Centofante™ 3 faithfully captures the spirit of his custom designs and translates it into a practical working folder with a hollow-ground VG-10 blade, FRN handle, and a sturdy back lock mechanism. The injection-molded handle features screw-together construction, an inlaid Spyderco “bug” accent, and an adjustable clip that can be configured for tip-up or tip-down carry on the right side.
Technical specifications
Lock
Back Lock
Blade Length:
3.14in 80mm
Overall length:
7.64in 194mm
Closed length:
4.5in 114mm
Edge Length:
3.04in 77mm
VG-10
Blade thickness:
.08in 2mm
Tip carry position:
Tip-Up/Tip-Down
Clip position:
Right
Handle material:
FRN
Knife weight:
2.5oz 71g
Grind:
Hollow
