At a glance
3.5in 89mm
8Cr13MoV
China
LinerLock
About
The versatile ClipiTool® Standard™ features a full-flat-ground, leaf-shaped primary blade, a can opener/small screwdriver, and a bottle opener/wire stripper/large screwdriver. Its PlainEdge™ primary blade locks open via a LinerLock mechanism, while the other two non-locking blades are held open during use by classic slipjoint spring mechanisms. All three blades are precision machined from 8Cr13MoV stainless steel and housed in a handle with nested stainless steel liners and textured black G-10 scales. A two-position hourglass clip provides the option of right-side tip-up or tip-down carry.
Technical specifications
Lock
LinerLock
Blade Length:
3.5in 89mm
Overall length:
7.9in 201mm
Closed length:
4.4in 112mm
Edge Length:
3.05in 77mm
8Cr13MoV
Blade thickness:
.09in 2.4mm
Tip carry position:
Tip-Up/Tip-Down
Clip position:
Right
Handle material:
G-10
Knife weight:
4.2oz 119g
Grind:
