COBOL™ C273TIP_Both
COBOL™
$352.00
Skip to product information
COBOL™ C273TIP_Both
SKU:C273TIP
COBOL™
$352.00
At a glance
3.63in 92mm
M390
Italy
SlipIt
About
Paul Alexander has become one of Spyderco’s most popular and prolific designers. His first non-locking folder, the NAND™ introduced us to his “techno-primitive” design style, which combines sleek, futuristic lines with classic simplicity. Springboarding off that pattern is his COBOL, which expresses his unique variation of the Ball Joint Non-Locking Mechanism with a more dramatic, Asian-inspired aesthetic. The upswept blade is a hybrid of a traditional Japanese tanto pattern and the katana-style point of the Americanized tanto. Precision machined from M390 particle metallurgy stainless steel, its saber ground primary bevel flows seamlessly into a flat grind at the faceted tip. On the opposite end of the blade is an extended “tail” that allows the knife to be opened one handed like a classic straight razor. The handle of the COBOL features solid titanium scales with integral spring arms and seated ball bearings. When the knife is opened, the ball bearings index holes in the sides of the blade to hold it in place. Hand pressure on the blade’s tail and a generous choil at the base of the edge further guarantee a safe, secure grip. To round out the completely ambidextrous design, the COBOL includes a reversible deep-pocket wire clip that offers a choice of left or right-side, tip-up carry.
Technical specifications
Lock
SlipIt
Blade Length:
3.63in 92mm
Overall length:
8.25in 210mm
Closed length:
4.77in 121mm
Edge Length:
3.24in 82mm
M390
Blade thickness:
.1in 2.5mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
Titanium
Knife weight:
2.2oz 62g
Grind:
Saber
Frequently bought together
Reviews
