Dragonfly™ 2 Salt® PlainEdge N A C28PYL2_Both
Dragonfly™ 2 Salt®
PlainEdge / N/A
$126.00
Skip to product information
SKU:C28PYL2
SKU:C28PYL2
Dragonfly™ 2 Salt®
$126.00
Edge
Blade Shape
At a glance
2.28in 58mm
H-2
Japan
Back Lock
About
The Dragonfly™ is a remarkably refined folding knife design that balances compact size with full-service cutting performance. Its unique handle shape and textured index-finger choil comfortably accommodate all hand sizes for a secure, non-slip, four-finger grip. The Dragonfly 2 Salt® takes this formidable package a step further with a hollow-ground H-2 steel blade, a high-visibility yellow fiberglass-reinforced-nylon (FRN) handle, and specially coated handle hardware. The result is a pocket-friendly, ultra-corrosion-resistant cutting tool that is perfect for use in and around the water. This extremely capable knife is available in two versions and a choice of edge configurations. One features a leaf-shaped blade and is available in both PlainEdge™ or fully serrated SpyderEdge™ configurations. The other showcases a hawkbill-style blade with a SpyderEdge cutting edge. To ensure convenient carry and immediate access, all versions of the Dragonfly 2 Salt include a deep-pocket wire clip that is reversible for left or right-side tip-up carry.
Lock
Back Lock
H-2
Overall length:
5.58in 142mm
Closed length:
3.33in 85mm
Blade thickness:
.098in 2.5mm
Tip carry position:
Tip-Up
Handle material:
FRN
Knife weight:
1.3oz 37g
Grind:
Hollow
Clip position:
Ambi
Frequently bought together
Reviews
