At a glance
3.83in 97mm
VG-10/ Damascus
Japan
Back Lock
About
The Endura® 4 Titanium Damascus honors of one of Spyderco’s most popular designs by expressing it with an impressive combination of old-world craftsmanship and state-of-the-art materials. Its breathtaking Damascus-clad blade is made from D.P.S. 15—a unique blade material produced by Takefu Special Steel Company, Ltd. of Japan. It consists of a VG-10 stainless steel core sandwiched between two outer layers of Damascus steel. Each of the Damascus layers is composed of 15 layers of forge-welded steel, beautifully patterned and etched to reveal the detail of the structure.
To complement its dramatic 31-layer blade, the handle scales of this knife are made from state-of-the-art 6AL-4V titanium. Precision machined and bead blasted to a handsome grey finish, the scales are supported by a stainless steel back spacer and mated to the blade by a high-strength back lock mechanism. All components are assembled with precision stainless steel Torx® hardware and meticulously hand finished. Extra touches of class include a stainless steel liner tube in the lanyard hole and a polished stainless steel clip configurable for left or right-side tip-up or tip-down carry.
Technical specifications
Lock
Back Lock
Blade Length:
3.83in 97mm
Overall length:
8.67in 220mm
Closed length:
4.92in 125mm
Edge Length:
3.45in 87mm
VG-10/ Damascus
Blade thickness:
.12in 3mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
Titanium
Knife weight:
4.2oz 119g
Grind:
