Byrd® Gooney™ BY24GPGYBoth
Byrd® Gooney™
PlainEdge
$80.00
Skip to product information
SKU:BY24GPGY
SKU:BY24GPGY
Byrd® Gooney™
$80.00
Edge Type
At a glance
3.44in 87mm
9Cr14MoV
China
Back Lock
About
Designed by Spyderco co-founder and Blade magazine Hall of Fame® member Sal Glesser, the byrd Gooney is a distinctly different folding knife. Its unusual blade shape blends the key elements of the sheepsfoot, hawkbill, and our Reverse “S” patterns to create an incredibly capable and versatile profile. Full-flat ground for superior edge geometry, the Gooney’s blade is available in 9Cr14MoV stainless steel with a PlainEdge™ cutting edge and 9Cr18MoV stainless steel with a fully serrated SpyderEdge™. Both blade choices are paired with a handle featuring gray, peel-ply-textured G-10 scales, nested liners, and a stout back lock mechanism. To keep the knife poised for immediate access, the handle includes a four-position pocket clip that can be configured for left- or right-side, tip-up or tip-down carry. A generously sized lanyard hole also allows the easy attachment of fobs, lanyards, and safety lines.
Technical specifications
Lock
Back Lock
Blade Length:
3.44in 87mm
Overall length:
7.71in 196mm
Closed length:
4.34in 110mm
Edge Length:
2.92in 74mm
9Cr14MoV
Blade thickness:
.11in 2.7mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
G-10
Knife weight:
3.7oz 104g
Grind:
Frequently bought together
Reviews
